Extra Battery vs. Collapsible Spare - Why?
Can someone please tell me what is the function and application of the extra battery?
Also, why does this option cancel the spare tire option? WHy can't you order both? Isn't the extra battery under the the Bose subwoofer? And doesn't the spare tire fit right in, around the subwoofer?
Thanks in advance.
Thanks in advance.
Overall, I call this poor planning on the part of the Porsche designers.
I checked with my dealer on do a switch to my 03 and price on the new sub-woofer was in the $800 range. Then you add the tire, and labor and ...........
"But is it really necessary? Vehicle is normally delivered with one battery. Can it not handle the load?"
The answer is: probaly not.
Read the dead battery threads here and on vwvortex.com (Trewg had only one batt)
My S has one. I had two dead battery experiences. Second time, dealer checked the cells. One was dead, they replaced batt. We'll have to see if the load reduces battery life significantly.
there is just too much sh**t going on when ignition is off.
second battery is cool when you dont use the car every day. my sl 500 have 2 batteries. a small one under the engine hood wich is only responsible for starting the engine and a fat one in the trunk for all the
electrical features like power seats etc.
i dont drive him 3 weeks and get the message batterie is low and some electrical features like audio etc are disabled. but with the first battery I could start the engine easily, drive some miles and load the other up. like allready been said - too much stuff going on in the cars even when they park.
so it seems to make sense. in case of the cayenne i dont ordered it cuz I prefer the spare wheel. when the battery is down its easy to find a second car to help you but when your tire blows somewhere in nirvana you run into serious probs. if i could have both I would take both.
It seems silly to me to have to sacrifice your spare tire for a subwoofer! And the idea of a second battery is appealing.
Perhaps it is best to order the extra battery option, then ADD the spare tire after the car arrives (I realize this raises the cost to something like $600 for the spare.
You could remove the subwoofer and have it or an aftermarket unit custom installed.
Or - - if you have an extra set of wheels/tires for winter, you could simply carry one around with you as a spare, in the back of the vehicle!
It wasn't the subwoofer that caused the "issue" - it was the "packaging" of the sub & battery that bounced the spare. The second battery in this application (Cayenne) was a bad joke from the beginning. The two batteries were connected electrically, not mechanically, thus if the primary were drained, the secondary would also be drained... There were two reasons for all early Cayennes in the US/Can having the 2nd battery - PCNA & PAG were frightened of warranty claims, and PAG couldn't give the option away in early deliveries in the home market, thus a pretty good oversupply of the components. All in all, the "right" decision would have been to go with a gel cell or glassmat battery from the beginning.
J
J
So, has the battery issue been resolved? Have they now supplied the primary with higher amperage?
Even if the two were always connected electrically, they would be able to supply double the amperage and, theoretically, last twice as long. Not a bad thing, really.
While we're on the subject; just a reminder:
If you're going to be away for 3 weeks (like
euro vacation) buy one of those trickle chargers and hook up to it.
The battery is under the front seat & might be a pain to take out to charge.
ALSO REMOVE THE GROUND when charging (hot), I don't think it's necessary on a trickle.
Originally posted by TIS330ci
i have the 04 turbo with 20 inch rims and no spare is that normal?
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Question on the spare. My Cayenne had it, but for some reason it was not included with the car. I called the dealer and they sent the spare to me. Is it supposed to remain uninflated while stored in the back? I am assuming this is where the "collapsable" part comes in?
Thanks!
BK
Thanks!
BK
