Boxster S Suspension Set-Up
I'm looking for info on suggested suspension settings for a '01 Boxster S (stock). Specifically, I want a setting that will strike a balance between good tire wear and improved handling on the track (emphasis maybe slightly more on handling since the car is not driven a ton). The car is a "spirited" weekend driver that will see occasional DE time...a street aggressive setting is what I guess I'm looking for.
What are the factory camber and toe-in settings on the '01 Boxster S?
Given my explanation, what would are the suggested ideal compromise camber and toe-in settings? I've heard the following:
FRONT:
camber: -1.0 front (or max out the camber setting)
toe: 0
REAR:
camber: -1.5 rear (up to -2.0)
toe: 1/8" toe in
Thoughts? What are other Boxster owners going with?
FRONT:
toe: 0
REAR:
toe: 1/8" toe in
I was thinking of doing the same. I know of a Boxster owner who's using -1.0 camber up front and -2.5 camber in the rear,without any unusual wearing.Handling has greatly improved.
FRONT
Toe in/ out 2
Camber L -1.6 -------Camber R -1.4
Caster L 7.8 -----------Caster R 8
REAR
Toe in/ out 2
Camber L -2.3 --------Camber R -2.2
Just be aware, I have a RHD car......
I took a photo of the tyres when I removed them [ to fit 285's]
I was pleased with how evenly they had worn.
**CLICK**
Toe in/ out 2
REAR
Toe in/ out 2
**CLICK**
