986 seat belt buckle replacement
Anyone know who to unplug the cable from the seat belt buckle from the wiring harness under the seat ? I got the seat out but cannot seem to remove the blue plug from the harness to install the new buckle.
Where you able to disconnect the wire harness from the car. If you haven't, there is a slide safety on the side of the plug. Pull it out and the connector will release. To get the actual seat belt harness out there is a small almost square black plastic piece that you slide up and off (I used a screw driver). Once it is off the harness comes right out. Fish the new write through the seat, clip it in place and you are good to go.
