LWF and clutch?
LWF and clutch?
I'm replacing the motor in my 2002 2.7L Box (IMS yada yada) and going to set the car up for strictly track use, no street. With it's limited power, I'd like to maximize the HP any way possible.
Besides removing factory seats, etc for weight loss, I'd like to do a LWF and clutch (worked wonders in my 993!)
I've read posts and seems the idea of LWF has mixed reviews. With that argument aside, what is the "right" combo to go with? Who's the best to buy it from?
i bought an assco lwf and plan to run it with the oem clutch(35000miles)
my car is a 2004, 3.2 l
i will put an ln eng ims bearing while im there
stock clutch is fine unless yours is shot or your running bigger power... my thought
i have an aasco w/ a spec clutch in my car. spec can make a sprung disk that dampens the engagement a bit so it's still reasonably smooth on the street. overall, it's a great mod. i can shift MUCH faster; the reduction of parasitic loss is also noticable. the car is just better to drive this way.
I can't weigh in on the LWFW, but I can remind you to grab yourself an underdrive pulley if it's not already on the list. Less power used to drive accessories, less chance of flogging your PS and water pumps to death.
I have read that more than a few times, it's on the short list
