Cleaning Rads
Cleaning Rads
Bought a 1999 Boxster with 39K miles. Even at this mileage, there is some pretty significant debris that will cause the temps to creep up. Cleaning is pretty easy. I used a wire brush and a shop vac.
Good job. Keeping those areas clean is important.
While you are in the mood check the body water drains. There are a pair under the plastic panels under the front trunk lid up by the cowl on either side of the battery cover.
There are two, one on either side of the clamshell up where the clam shell arms reach.
