Why are ads for Boxters devoid of any mention of IMS repl?
I understand the failure mode. What I don't understand is the relationship to oil changes. If there is not enough lubrication to get into the bearing, then changing oil would have no effect on the failure mode.
Not being obtuse, but again, the failure mode relation to oil change isn't related.
But as the "seal" is not really a seal but a plastic shield the oil slowly entered the bearing.
The theory is that Porsche extended its oil change intervals which, coupled with short trips and long periods of inactivity caused the acidic byproducts of combustion to build up in the oil. These acids tend to attack the bearing surfaces after the original grease had been flushed out, causing brinnelling and pitting of the steel ***** and race, eventually causing the bearing to fail.
The hollow shaft that connects the two sets of timing chains eventually fills with this oil/acid mix (no drainage facility), so the ball bearing literally sits in this corrosive enviroment. Quite a few people have noticed when replacing the IMS assembly that once the bearing was removed quite a lot of this putrid oil drains out of the shaft.
That's the theory anyway..........
