Rough idle on cold start
I've read from plenty of people that the snorkel delete is benign and possibly even beneficial. It's a mass produced, globally marketed, relatively cheap sports car designed to start up on a whim every day in multiple environments without a problem, how intolerant can the intake system be?
But I am suspect of the STP filter. I bought it and an STP oil filter cartridge at the same time. The oil cartridge had severe glue overrun and did not fit the oil tube at all. I inspected the air filter thoroughly after seeing the oil cartridge and didn't see any problems, but I suppose that is no guarantee. I only installed it because I already had it. Needless to say, I'm not buying anything even remotely motor-related for this car from AutoZone/Advanced Auto/O'reily's/etc again (the taillight bulb I got from O'reily's has been working fine I must say ) except for the oil itself. Barring any major discoveries this weekend, I will order a new air filter from Pelican and clean the MAF sensor again when I install it.
For weight distribution?
It is there for a reason. To tailor the air flow into the air box and beyond.
The reason the car behaves as you state: "sports car designed to start up on a whim every day in multiple environments without a problem" is because Porsche paid attention to things. It just didn't slap the car/engine/intake system together.
Air Filters and AoS smoke bombs
I am a bit confused. You wrote:
"I replaced the air filter with an STP unit about 1k miles ago. I thought the MAF sensor might just need a good cleaning, so I cleaned it per the Pelican Parts site's instructions. No change. I've read that an oiled air filter can mess the MAF sensor up, so I am a bit suspicious of the STP unit"
Soo... i read between the lines that this must have some oil, and must be STPs answer to K&N. Yes? No? The fouling comes from foam-type filters that you must apply oil to to make them retain dirt. Like a 1960s lawnmower. if oyu put a paper element in, ignore it (however, i would use hengst, WIX, Mahle or......GM/Delco). My favourite is GM or WIX.
As to the AoS - sporadically. Sometimes as you drive, under high G-forces. Mine did it once - ont he track, on a hard left hander - everyone thought my motor blew for sure, including me. Except it was running happily (caugh, caugh)
As it worsens, every start-up when motor is HOT.
Grant
Grant
Did you clean out all the junk from the air box when you removed the old filter? I usually take a shop vac and clean it out.
Had a car with a running problem, turned out to be a cigarette butt in the air box that was bouncing around and hitting the MAF.
