Fog Lights not working
I have a 2002 Boxster with 80,000 miles. The fog lights worked last year but are no longer working. Both front fogs and the rear fog light is not coming on. I have checked the bulbs and all are good. I checked fuse A7 and that is also good. I have swapped in a new relay in location 12 and still no fog lights. I have replaced the light switch and still no fog lights. FYI all the other lights are working properly. I have checked both sides of the fuse holder with the ignition turned on and the fog light switch turned on and no +12V on either side of the fuse A7. Any help in solving this problem would be appreciated. Thank You, Jack
Here is the solution to my Fog Light Problem:
As I said earlier the A7 fog light fuse was not getting 12 volts. This 12 volts source is an output from Terminal XE Relay #9. I found that the Relay #9 female connection at pin 87 was not making good contact. After tightening up the female connector the fogs are now working. I wanted to send this info on. Maybe it will be beneficial to someone else that has a Fog Light issue.
Thanks,
Jack
Thanks,
Jack
