This one has got me. This car is new to me, 2008 S. The brake lights are not working. All other lights function... turn, running, backup. The CAL (center light over rear lid) is also working. Checked on fuses Row A F6 and Row C F4. All good. How can the CAL light function and not the brake lights in the tail not function if the fuses are good? Help!!!
Forgetaboutit! Took apart brake light switch above pedal. Cleaned contacts, pass side started working. Removed and replaced bad stop bulb on driver's side. GOOD TO GO!!!
