Replace Rear Plastic Window With Glass ?
I've searched all the threads re:replacing plastic rear windows. I've seen comments and references about the glass replacements. But, I have not seen any comments from anyone that has actually done this. I would think the glass window may be a bit smaller then the plastic--but by how much? I've also seen comments that the glass window may inhibit access to the engine compartment.
It would be nice to have a clear rear window and with an electric defroster. The tops I've seen advertised come with the harness for the rear defroster. And a side benefit would be the ability to change the top color from black to whatever.
My questions are:
has anyone replaced their plastic with glass?
are they happy with the end result?
how much did it cost and was it worth it?
Thanks.
My questions are:
Thanks.
Porsche Nut
My questions are:
Thanks.
My questions are:
Thanks.
http://www.gahh.com/store.php?cPath=57_341_3005
Here's a link to someone who did it:
https://rennlist.com/forums/996-foru...ht=rear+window
Charlie C,
Thanks for the links.
The info on the guy with the C2 is a bit dated.
They now offer the glass windows with the harness for the defroster attached.
Also, in addition to GAHH, there are 2 other suppliers I came across. Their descriptions of the top material and the way the glass is attached to the top sounded exactly the same as GAHH's but at almost 1/2 the cost. Cabrioworld has an ad in Panorama and the other is Autotops Direct.
I'm really hoping to hear from anyone that has actually done this and which supplier they used.
And how happy or unhappy they are with the end result.
Thanks for the help.
Had one (I think it was a GAHH), hated it.
smaller window, couldn't service the engine top worth a darn.
sold it to someone else.
Mike
Mike
My questions are:
Thanks.
My questions are:
Thanks.
The top hardware along with the top provides a glass rear window, and a top that fits better and does not interfere with access to the engine.
The cost is not gruesome. IIRC some have reported buying the hardware for around $600.
The next time my 02 needs a new rear window or if the top leaks I think I'll look into doing the 03 or newer retrofit to my 02.
Sincerely,
Macster.
Mike,
How long ago was that? I wonder if the glass tops today are improved over the ones from a few years back.
One of the things I plan on doing is making a call to a few of these companies and asking them for the measurements of the glass window. At least then I could make a legitimate comparison. I also need to find out from them if their top will interfere with access to the engine.
I was hoping to find someone on this site who actually had replaced their top in the past year or 2 and benefit from their experience.
Macster,
I guess I need to do some research on this alternative. I had not heard much about it.
Thanks.
MWest
Macster,
Thanks.
MWest
2001 boxster S
So if I want glass window with no interference to the top of the engine, I need to get a complete top including the mechanism from a 03-04?
Maurice, the best top guy I know, produced a series of articles on replacing the window, installing a newer top, etc.
http://sites.google.com/site/mikefoc...%26replacement
The articles will describe for you in step by step detail with pictures the various options (window replace, top replace, frame replace, etc).
Maurice's article, along with the 101projects book, and a few other websites are all I used to install my glass GAHH top on my '99 w/ plastic.
Glass window is definitely smaller than the plastic window, but I hardly noticed it. In fact, after a couple months, I don't notice it at all.
Can't get the top fully into service mode, but it does get pretty close! I have to use a cargo strap to hold the rear of the top up and access is only slightly limited.
Given the benefits of the glass, I gladly accept the drawbacks. Your mileage may vary...
How often do you have to get full access to the engine? And if you do, can't you just remove the top frame and all? I never found that strapping up the top was a big deal, since the original was designed to be secured that way.
limited engine access isn't the issue I have. It's that the new canvas will have a hard time stretching enough given the frame hardware has become loose and can't be tightened everywhere. Several owners who have done the aftermarket conversion from plastic to glass have complained about this. I had this same experience with a previous convertible. The new top was latched shut for weeks and despite the car having been driven only on weekends, the frame never produced enough torque if you will, to stretch the new fabric making operation difficult.
