Two separate coolant leaks on my Boxster
I took my 2000 Boxster S for a little drive this morning. I planned to do an oil change (more on that in a separate posting) and went to get some supplies.
When I returned home, I noticed coolant dripping out from the left front (running out under the bumper). I said some choice words and then decided to look at it while the car is jacked up.
When I jacked the rear of the car up, I heard fluid running out from under the car. There was a HUGE leak in the right rear of the car. I popped the trunk lid and saw the coolant level drop and then stabilize.
Since then, it has been steadily dripping. I have a picture of the source (or what seems to be the source) of the leak. I have no idea what this part is (I think it might be associated with the water pump). I tightened the bolts, but no luck.
Any suggestions? By the way, I removed the bolt and re-installed it to see if the dripping increases or decreases. No change.
I got under the car and squeezed the coolant tube. Everytime I did that, coolant would start dripping out of that spot again.
I removed the coolant pump (WHAT AN ORDEAL) to see the condition of the pump and gasket.
See the pictures below what I found. There is no play in the bearing.
Could this be as easy as just the gasket? Can I be that lucky?
How would I know if it leaked at the pulley?
The areas that I marked up are very rough and could be the source of corrosion/leaking.
![](http://www.randombitcorp.com/boxster/P1030037_marked.jpg)
![](http://www.randombitcorp.com/boxster/P1030040_front_marked.jpg)
![](http://www.randombitcorp.com/boxster/P1030042_back_marked.jpg)
