Boxster & Boxster S (986) Forum 1996-2004
Here's what I found in blown engine number 2....
Old 05-18-2011 | 01:39 PM
Byron in MS's Avatar
Byron in MS
Default Here's what I found in blown engine number 2....
metal shavings the size of a dime. Looks as though someone with a wood plane has been inside the engine?!? This was stuck to the handy magnetic drain plug that I got from LN. Any guesses as to the cause/source of the filings and shavings?
Old 05-18-2011 | 05:03 PM
Randy V's Avatar
Randy V
You have 2 blown engines?
Old 05-18-2011 | 05:11 PM
racer's Avatar
racer
Yikes.. no guesses here.. how does the oil filter look when you cut it open? How did the rest of the oil look when it came out? What do you suspect happened?
Old 05-18-2011 | 06:26 PM
Byron in MS
2 on this car...This one was a used engine that only made it 50 miles.
Old 05-18-2011 | 06:45 PM
Randy V's Avatar
Randy V
Well, that's one way to keep the mileage down on your car.
Old 05-18-2011 | 07:13 PM
Byprodriver's Avatar
Byprodriver
Looks like spun rod bearing
Old 05-18-2011 | 07:47 PM
harryrcb's Avatar
harryrcb
I got shavings that big with a seized IMS bearing (engine still running) was your engine still running? any noises or rough running? Name:  005.jpg
Old 05-18-2011 | 09:17 PM
Byron in MS
Originally Posted by harryrcb
I got shavings that big with a seized IMS bearing (engine still running) was your engine still running? any noises or rough running? Attachment 537464
Yes, it was still running, but sounded like a bag full of wrenches when I shut it down. I had just installed the LN IMS upgrade, so I am hoping that is not the culprit. I am leaning towards rod bearing. I will be tearing the engine down over the next few weeks and will report the findings!
Old 05-19-2011 | 10:47 AM
harryrcb's Avatar
harryrcb
Yeah, If you heard those wrenches I don't think it was the IMS either, good luck
Old 05-19-2011 | 11:44 PM
herman maire's Avatar
herman maire
That really, really SUCKS !!!!
Maybe the chains have rubbed through the plastic and now grinding the cast/aluminum chain guide frame.
Old 05-30-2011 | 06:41 PM
budmanv24's Avatar
budmanv24
But aluminum is not going to stick to a magnetic drain bolt. Only ferous engine bits will. So what does that leave us with...cams and crank would seem like the most likely culprits.
Old 09-02-2011 | 05:13 PM
powderhound's Avatar
powderhound
Question
any new info?
