Left foot braking
Left foot braking
Hi Crew,
Does any body know if you can disable the throttle cut out when you brake? You cannot left foot brake the way the car is wired from the factory.
Thanks,
Craig
Thanks,
Craig
Still plays with cars.
You cannot disable the engine cut out on any Porsche since 2000. They are fitted with e-gas which is required to allow PSM to work. Your gas pedal is not connected directly to the throttle body, rather it is an input to the computer.
If you apply the brakes BEFORE the throttle you can then apply throttle while on the brakes. Not useful except for drying your brakes.
Best,
Best,
I've got an '03 S and regularly left foot brake. I just did a 3 day DE at Mid-Ohio and the only time the engine cuts power while on the brakes is if the ABS gets activated.
If you are left foot braking for more than 2 seconds, I would say you need to brake less.
As previously said, programming can rid it should you really feel the need.
