99 Boxster Check airbag light
Dear all,
I have been stalking for a while now, and finally decided to register and contribute to this great online community!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Question 1:
If the Check Airbag light comes on, does it mean that my airbags will not deploy in an accident?
I have read different things, totally opposite, from online forums and from Porsche mechanics. What do you know?
Obviously, my motivation is clear: If the airbag system is operational and I am safe in the case of an accident, then I will be willing to live with a red light in my face.
But, if the airbags will not deploy in an accident, I will definitely suck it up and pay the $1.5k my mechanic is asking for.
To make this decision, I am relying on the collective knowledge of this group. Please help!
Thanks.
Newbie123
Question 1:
Thanks.
Newbie123
Dear all,
Question 1:
Thanks.
Newbie123
Question 1:
Thanks.
Newbie123
Now the error may be due to a bad connection. Or the light may be on cause the car has had too many air bag deployments and the air bag controller counter is full and the air bad light is on because of this.
Sincerely,
Macster.
Doesn't sound serious.
However, if the cause could be traced to the car being a flood car, then it is serious.
Sincerely,
Macster.
More than likely is just a bad buckle. They go bad all the time. You can get one for cheap at suncoast porsche:
http://www.suncoastparts.com/product...y_Code=986seat
Easy to install, one bolt and one plug. After you install it you will need to clear the airbag code.
The buckles do fail often but there is also a TSB to replace pins in the body side of the harness for the buckle connector. If the problem persists eventually you can replace the airbag control unit with an updated version that is less temperamental.
This was a common problem in the early Boxters and Carrera.
Technical Service Bulletin #6924 explains the repair.
You should see fault codes 45, 46, 48, 49. Any or all. It could be one side or both.
The repair consist of replacing buckles, contact pins and modiffying the ground connection.
