Painting Brake Calipers (pics)
Posted this in the 987 section, however, I had this same problem with my 986 Boxster when I had it, so I figure it could be useful here as well.
I've always hated the way the calipers looked on the Boxster, so I decided to paint them. I used a Dupli-Color Brake Caliper kit. It includes a brush on epoxy.
I didn't want to take the calipers off, so I just took the pads and all attached hardware off, and did the work with them on the car.
I cleaned the calipers with the solution in the kit. It was in an aerosol can, basicly just brake parts cleaner. You have to take your time with this step. If they are not 100% free of dust, the paint will seperate. This took about an hour.
Next I applied the epoxy. This step took the most time (about 3 hours), as it required many coats. At first it looks really bad, but as the coats go on, it starts to look better. I waited 15 minutes between coats. Seems to work best if you do two calipers at a time.
I let them dry overnite, then I put back the pads and hardware back on. I also applied "PORSCHE" decals I purchased on ebay ($6).
And here they are with the wheels back on:
I've put about 5k miles on them since, and they still look great (I do wipe them down every time I wash the car). Here's a recent picture:
