Boxster & Boxster S (986) Forum 1996-2004
Sport Exhaust System??
Old 11-23-2009 | 10:43 PM
texasviany's Avatar
texasviany
Default Sport Exhaust System??
How does this option work? Like the '70 GTO Judge package...where the switch opens the exhaust? (LOL) Or is is an electronic gimmick that "makes" noise. Am I better off skipping this option and going after market to add noise and a couple more HP?
Old 11-24-2009 | 01:30 PM
First986NJ's Avatar
First986NJ
I believe the switch operates electronic valves that allow a portion of the exhaust output to bypass the first chamber or two of the muffler, thus making it a bit louder.
Almost any aftermarket exhaust that you add for sound will have some level of resonance, and if that is not desired, the sport exhaust is the only way to fly from what I have read/been told.
Old 11-24-2009 | 02:53 PM
StatmanDesigns's Avatar
StatmanDesigns
I have the PSE (Porsche Sport Exhaust) on my 2000 Boxster S. The PO installed it and did not hook up the valves. If the valves are not connected the exhaust is always in "loud" mode which is fine since even in loud mode it isn't really loud. The valves are there to make the exhaust quieter when at lower RPM. I like my PSE, and there is zero resonance, but it is expensive.
Old 11-24-2009 | 04:10 PM
gerrygug's Avatar
gerrygug
Here is the poor mans alternative
Costs about $300.00 to have someone fabricate and install.
Darin Fister in Brentwood CA has a shop doing these modifications.
Sounds great. No resonance. Inexpensive alternative to PSE.
Old 11-24-2009 | 08:25 PM
Carmin's Avatar
Carmin
I bought my 08S off the lot and it has PSE. While it satisfied my curiosity about this option (my 99 base did not have it) and it does sound a bit better with PSE on, in my opinion it is not worth the price. So, a good question might be what would I pay for it? It costs $2,500; I think it is worth about $500 - $800. Keep in mind, the car sounds great at high rpms w/o it.
Old 11-25-2009 | 01:07 AM
papasmurf's Avatar
papasmurf
I have the poor mans PSE as well. I paid less than $300 and pickup up a used S muffler off of ebay. It is the best thing I have done. 1.5" bypass pipes sound great and are not really noticeable until 3500+ rpm.
Old 11-25-2009 | 04:46 PM
Mabuhay's Avatar
Mabuhay
If you are looking for something louder, then get an aftermarket. If you're looking for something to give you "a couple more HP", then look for something other than an exhaust since that just serious BS when they tell you that you get 15 hp (or something crazy).
+1 the "loud" isn't really loud while inside the car or near the car. BUT, if you are a bit further away from the car, the exhaust sounds louder. This is because low frequencies are heard farther away than close by. My wife knows I'm coming home when I'm about 1 block away from the house.
Overall, the "Stromung" exhaust that I had on my E36 M3 was the sweetest exhaust ever for me... And I've owned a few brands and heard a lot also.
