accelerator does not work on a 02 S
I'm putting together an Boxster S that had a fire incident a year ago
and everything is coming together and i have the car started but the accelerator doesn't respond at all...
And when the car is running it jumps from 800 rpm to like 1200 rpm and if u put your feet on the brake pedal it's like that motor sufficates:S
I'm thinking vacuum but i can't find anything wrong
Do u guys have any idea on what can be wrong
When i got the car i was already taken apart sooooo i'm not 100% on the vacuum lines
there wasn't much damage but i changed the wiring loom for the whole engine and put the manifolds back on.
It's sounds just like this thread here but i can't get it to work
https://rennlist.com/forums/rennlist...first-cel.html
I need a vacuum diagram
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
As u can see there's no outer damage and everything else works fine
![](http://pic20.picturetrail.com/VOL1477/5631844/21076561/345221899.jpg)
Nice colour, is that aero I option? I'd be interested in seeing a pic from both the front and rear
It does seem to be a vaccum leak. I don't have a layout of the vac lines. I suggest checking over at renntech.org
Idle should not fluctuate, rise and fall, even a bit.
If you step on brakes and this affects engine idle speed, this suggests the brake vacuum booster vacuum line might be leaking, incorrectly connected, or there could be a leak in the booster itself.
Find booster and any hoses from this and trace their route and see where they go.
In meantime, I'll see if I can find a vacuum line diagram.
Sincerely,
Macster.
