Relocating the horn button to the dash
About a month ago I installed my very cool (and functional) Momo steering wheel. While this wheel does have a horn button, I could not figure out any way to utilize the stock wiring. It should be noted that when I removed my old stock steering wheel that I needed to remove (and hence destroy) the spindle wiring which carries the wiring for the airbag and horn.
So, I scoped out a perfect place on the dash for the horn button namely the ‘mirror image’ spot of the ciggy lighter (presumably used on cars with RHD). I bought a small pulse on/off button from Radio Shack (a few bucks).
I removed the steering wheel and then the top piece of plastic covering the steering column (2 Torx screws and 4 philips screws). There are 4 wires running together. The two brown wires are the circuit for the horn. I had an extremely difficult time stripping these wires as they tended to break before stripping. I’m guessing this is a result of the age of the car.
I then connected crimp connectors to the two brown wires behind the wheel. To route the wiring through the dash I did the following. I passed a speaker wire down through the steering column until it came out in the footwell and behind the dash. I then passed a second speaker wire through the hole in the dash where the horn was to be transplanted (the plastic trim simply snaps out). I then tied the wires togther and pulled it through. I hooked up the wires to the connectors. I then drilled out the dash trim hole until it was just the right size to accept the Radio Shack ****. Hooked it all up and it works like a charm. The button looks like its always been there. I want to find a small trumpet icon to put on the button to complete the project.
Here are some pics….
![](http://gallery.me.com/meowmeowmeow/100194/IMG_0443/web.jpg)
![](http://gallery.me.com/meowmeowmeow/100181/IMG_2011/web.jpg)
This is where the Torx screws are holding the column trim on:
![](http://gallery.me.com/meowmeowmeow/100194/IMG_0444/web.jpg)
Access the two brown wires:
![](http://gallery.me.com/meowmeowmeow/100194/IMG_0431/web.jpg)
Run a wire through the dash as shown (done by running a wire ‘down’ each hole then tying them together and pulling through):
![](http://gallery.me.com/meowmeowmeow/100194/IMG_0433/web.jpg)
Drill out part of the dash trim and secure the horn button:
![](http://gallery.me.com/meowmeowmeow/100194/IMG_0438/web.jpg)
![](http://gallery.me.com/meowmeowmeow/100194/IMG_0439/web.jpg)
Connect it up and shove it back in !!!!!!!
![](http://gallery.me.com/meowmeowmeow/100194/IMG_0442/web.jpg)
