98 2.5L vs 2000 2.7L
Hi All,
As is probably everybody, i am looking at the current prices of boxsters and seriously considering purchasing one. Just asking for people who currently own and drive them for their opinions and what to look for and most importantly what to be aware of.
I have two in mind;
1998 2.5L
manual
100km's and full service history
2000 2.7L
manual
55km's and full service history
The main reason for the question does the variance in price (about 35%) justify the difference in price
thanks in advance for the advice.
Cheers
Clayton
I have two in mind;
1998 2.5L
manual
2000 2.7L
manual
Cheers
Clayton
Ironman 140.6
What are the prices?
Are there option differences as well?
Have you driven each car in question?
IMHO, the jump from the 2.5's to the 2.7's is larger than 16hp might suggest. The newer motor had a lot more torque down low and also reved higher.
'00's also got a revised interior and many other small refinements. I'd recommend a few test drives if you have not already gone.
Clayton, I'd go with the 2000 model. In particular because of this problem with the earlier models -> "1. Porous Block Early '97 engines had a "porous block" problem that generally massively failed within the first 10k. All are thought to have been replaced by now. The best description of this problem I know of is here.
2. Slipped Sleeve Mid '98 thru early '99 engines had major internal engine slipped sleeve problems that would cause total engine failure. Porsche replaced all the engines that experienced the slipped sleeve problem under warranty (and many after warranty). A replaced engine is a good thing as the replacement engines have actually been more thoroughly tested than the ones put directly into new cars. The best description of this problem I know of is here. I know of nowhere where it lists a manufactured-after date or an engine serial number after which the problem was corrected so you could know the problem will not affect a specific car."
This guy has a lot of good info put together on one site that should answer a lot of your questions.
http://mike.focke.googlepages.com/mi...oxsterwebpages
I own a 2000 2.7 Boxster and have had great luck with it. I've got 92,000 miles on it and have done all the maintenance myself including a few "upgrades" like rear speakers, short shifter, etc. It's been a blast to own and drive and I'd recommend one to anyone. Good luck in your search!
Hi All,
thanks for the help and info....i ended up finding a really well looked after 2000 boxster s........and decided life is too short. Just awaiting the ppi before i purchase the car.
Cheers
clayton
Cheers
clayton
Ron
