No throttle response 2002 Boxster S
Location: Trying to be the driver my car wants me to be
Here is the history of my throttle problem...
Have had the engine rev from time to time at an idle around 1100 to 1500 rpm's, then settle back down with engine hot and cold. This comes and goes.
Was at Lime Rock Wed and Thursd and had the throttle response totally shut off. The car was still at a normal idle but the throttle would not respond. Upon turning the key off then turning it back on the throttle worked.
Here are the following codes that were generated...
1126 O2 sensor
1123 or 1133, not sure which one is correct
1125
1132
1508
1505
5525
The codes happened at different times and the clusters indicate they happened at the same time.
Interesting that none of the above codes are related to a throttle code. I feel like an idiot that I cannot find the paper where I wrote down what these error codes are for. A tech had a computer there to scan the car.
I went down to a lower run group to lower my speeds to see if it would happen again as we cleared the codes. It happened 2 more times
Any thoughts as to what might be causing this?
Anybody have this or a similar experience before?
Thanks in advance for the info,
Mike
1126 O2 sensor
1125
1132
1508
1505
5525
Mike
1126 O2 sensor
1125
1132
1508
1505
5525
Mike
1126 O2 sensor
1125
1132
1508
1505
5525
Mike
"1123 or 1133, not sure which one is correct" P1123. Oxygen sensing adaptation range 1 (cyl. 1-3) lean limit.
"1125". Oxygen sensing adaptation range 1 (cyl. 4-6) lean limit.
"1132". P1132 not in my reference.
"1508" and "1505" not in my reference.
"5525" not in my reference.
From the codes that are in my references I think your car has fueling problem. Fuel flow/pressure not always up to snuff and engine controller attempts to adapt by "adding" more fuel, leaving injector on longer. Engine controller relies up fuel pressure remaining constant cause it only varies the width of the injector pulse, the time the injector is open to control how much or little fuel to inject.
The problem is intermittent and when it goes away the engine controller will of course try to unlearn the enrichment adaptation and sometimes exceed the lean limit threshold.
I'd advise looking into the fueling system: pump, filter, pressure regulator, return lnes, vacuum lines, etc. and addressing anything you find amiss.
Then clear codes and drive car and see what other codes, if any, appear.
Sincerely,
Macster.
