Which Power Steering Fluid and Which Wiper Blades to Buy?
I did a search but found few 986-specific recommendations.
So yeah, I need to top off my power steering fluid and was wondering what we can use and where to get it from.
I'd also like to replace the wiper blades for the first time and am unsure of which product I should buy and where from.
Any suggestions?
Any suggestions?
I was worried about that but not positive. I haven't noticed any liquid deposited underneath the car or have seen a warning light but there is a little groaning going on by the steering wheel when I turn it a lot at at low speeds. I had a power steering leak in a previous car and it was almost the exact same experience.
I just replaced my wiper blades with standard ol' Anco refills. I've been using Anco for years and they work great. They are cheap enough to just toss out every 6 months (which seems to be the life span of most wiper blades regardless of cost).
OEM blades only. I've had enough of aftermarket ones not fitting properly (i.e., not curved, wrong length, chattering). The latest OEM version is a good design over the early ones.
Also, get the stock Pentosin power steering fluid. You'll likely wind up buying a quart -- a lifetime supply, and you'll be a hero among everybody in Miami who needs a top-off.
