Boxster hardtop
We have a Boxster hardtop in blue (Ocean, I believe). Obviously it could be painted if needed. Let me know if you would be interested. Top is located near Cleveland, OH.
Brad Kennett
bkennett@stoddard.com
Brad Kennett
Ebay has them from time to time, but they aren't nearly as plentiful as 996 tops. Costs are all over the place on ebay, as it depends on who is looking and if the color is something a bidder needs without having it painted. I see you are from White Pine. I grew up near there and used to own a house in Baneberry. I wish I still had it. Good luck in your search. If you need parts or info and I can help, just ask. It would be a pleasure to help out someone from White Pine. You don't see that come up on the board too often.
My Boxster is Forest Green metallic, the hard top used to be yellow. You can only see yellow when you take it off. It is difficult to paint the inside edges. Mine matches perfectly, even on the odd color.
