Rear spoiler maintenance
Does anyone have information on regular maintenance of the rear spoiler i.e., piston lubrication? I have not had time to read through the maintenance manual. Anyways, I noticed a low groaning sound the duration of the lift time of the rear spoiler when I went to clean the under side of it. It appears to work properly when driving, since I have not received a warning light in the dash. I assume it is a lubrication issue and if so what is the recommended lubricant?
Any input will be useful and I will respond with what the manual says once I get around to it.
Thanks,
Carlo
Thanks,
Carlo
I've never noticed an unusual noise in my 2000, but would love to know if any regular maintenance needed doing. If I fined something out before you receive a post with an answer, I'll forward it on.
I'm also interested because mine goes up fine, but when it comes back down, it doesn't come all the way down. I usually have to push it down the last 1/4 inch or so. I've checked the alignment plenty of times, and it's fine.
subscribed.![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
subscribed.
Thanks,
Carlo
Thanks,
Carlo
So far the spoiler raises fully and lowers fully. There is some looseness to the spoiler (when down -- I've not bothered to check for this up and I don't think I ever have so would have nothing to go on).
Only once has the spoiler given me any trouble. It failed to go down. Using the button I could not lower the spoiler.
Drove car to lunch and back and when I returned to office after lunch warning light off and spoiler down.
Never did figure out what happened but I do know this happened shortly (days? weeks? sometime anyhow) after I washed engine. I suspect some connector got a bit damp and caused some problem. Long shot but all I can think of.
Sincerely,
Macster.
Checked out the shop manual and the only information I could find was about removal / installation of the rear spoiler. I searched the web and no info as of yet.
Thanks,
Carlo
2003 Boxster S
2006 Mazda3
1970 Camaro Z28/RS
Thanks,
Carlo
2003 Boxster S
2006 Mazda3
1970 Camaro Z28/RS
I finally heard back from the PCA Tech Q&A...
Question:
Is there any REGULAR/SCHEDULED maintenance that needs to be done on the Boxster rear spoiler? I noticed a low groaning sound the duration of the lift time when it is deployed from time to time.
Answer:
Other than a extended height adjustment there is no regular maintenance required for the retractable spoiler. You may want to check that the spoiler is free of any debris. The spoiler can be cleaned in the same manner as the vehicle exterior.
Hope this helps!
Question:
Answer:
Hope this helps!
Interesting thread here. I've noticed that my spoiler doesn't go up at all when i hit the button. Haven't had time to figure it out but didn't look like there is anything blocking it or stuck in there when I open the trunk. From what I was told, boxster spoiler motors are pretty solid.
Mine went out. Tried the relays, no luck. Spoiler goes up about an inch and then stops. Has trouble retracting as well. Took it to the dealer and they diagnosed as a bad motor. They wanted $800 to fix it.
Send me a PM with your email address that can accept a PDF file and I'll send you what I have. Oh, the section is 7 pages. I do not know what the PDF file size will be. (I have to run the pages through a copier that creates/emails me a PDF file and then attache the PDF file to an email to the supplied email address.)
Sincerely,
Macster.
Relays? What about a fuse?
The motors may be solid, check that they are solid: My 02 Boxster's spoiler still works and the car has over 249K miles on it; but nothing lasts forever: The motor could have died.
As an aside: the spoiler in my car might be a bit noisier than it used to be but I haven't bothered raising it manually and I know I can't hear it go up at speed, but as long as the spoiler goes up when it is supposed to and goes down when it is supposed to... I ain't complaining.
Sincerely,
Macster.
Sincerely,
Macster.
Sincerely,
Macster.
