Water leak in passenger front carpet
Anyone else experienced water in passenger front carper of 2001 Boxter S ?
Looks like it is coming from the lower inner door trim, which is soaking wet.
Should there be a water proof membrane(polyethylene) or such like in the door ?
I have dissassembled the door and find that water is leaking past the window scraper seals and down the window, crossing over to the inner door skin and down to the lower inner door trim "carpet" which is soaked. Passing and soaking a number of wiring looms and connectors on the way.
I was considering adding a water prooof membrade to direct any water to the lower door drains.
Any experiences good or bad with this solution ?
Rgds
D4VMD
Rgds
D4VMD
Rgds
D4VMD
Rgds
D4VMD
The seal is made of a waterproof rubber/foam material and it serves the exact purpose that you are thinking of accomplishing. Wash water or rain water will normally find its way past the window seals and it is supposed to stay inside the metal door frame and exit through (2?) small drain slits on the underside of the door.
Regards, Maurice.
Thanks Maurice, I did find the thin foam skin, but someone had been there before and it looked like it had been replaced but not well sealed. The water was still getting past this skin via the wiring harnesses and was collecting in the lower door inner face "carpet".
I have installed a couple of strips of thick poly sheet inside the door and this seems to have done the trick.
Fingers crossed.
Best regards
Dave
Fingers crossed.
Best regards
Dave
