aluminum bezel puzzle - Boxster gurus help!
Hello, everyone! I was hoping somebody here could help clear this up for me. I need to find a set of silver gauge bezels for a Boxster. I've seen standard Boxsters with what I assume is colored plastic around the gauges. I've also seen Boxster S's with "aluminum" bezels. Of course asking the dealer muddied the waters considerably. So...are the "aluminum" bezels truly aluminum, and if so are they just a separate add-on piece? Also, are the painted plastic bezels separate, or are the gauges painted? Any answers will be GREATLY appreciated!! Thanks in advance!
The 3 rings are removable for painting from the rest of the part. It is a pain because they are glued on and you have to break the glue bond to get the rings off. You could try to paint them in place but it would be hard to mask off the clear plastic lenses. Jeff
I wanted to bump this to see if anyone with an S can tell me if they're truly aluminum or removable. Jeff - it sounds like you speak from experience...thanks.
ArticCzar,
I see you are in KC, why don't you come to the next breakfast this Saturday at LePeep, or the next social night and those of us with Boxster S's will let you check out our rings first hand. Info on meetings can be found at:
<a href="http://www.smiley.net/kcrpca/" target="_blank">http://www.smiley.net/kcrpca/</a>
The picture is from a 2001 or newer S, that is why it has the white/silver dials and the silver trim rings. I only mention the year as the new style cluster can out in 2001 and that is the one in my picture.
The rings on the new and old style cluster can be removed but it is a bitch not to break anything. Also, the plastic lenses are glued to the rings. The silver rings, just like the standard black rings, are plastic, just painted silver on a S. I took one off to show you.
If you want to take your black rings off to have them painted then do not break anything as you cannot get parts from VDO. I have 2 freight damaged instrument clusters (old and new style)that I use to play around with. Jeff[IMG] <a href="http://www.986host.com/albums/ToolPants/cluster_trim_ring2.sized.jpg[/IMG]" target="_blank">http://www.986host.com/albums/ToolPants/cluster_trim_ring2.sized.jpg[/IMG]</a>
