B&M shifter installed in factory shift housing
I installed the B&M in my 02 C2 and just removed it, so I can try out the Techart version. When installing the B&M, you have to cut the original shifter bushings, so you can't return to stock without purchasing an entire shifter housing (including shift lever, bushings, etc.). This part reatils for $188 from Porsche. I was able to buy it for less with a factory coupon that I received in the mail.
So, if anyone wants to try the B&M, I am selling it pre-assembled, adjusted, and lubricated in the original factory shift housing with cable end connectors, so it's a simple half-hour job now to go back and forth. It's in perfect condition
Contact me if you'd like to buy it or trade me a Techart.
Thanks,
Grant
Thanks,
Grant
