Boxster S Transmission / Conversion Question
I am wondering if the Boxster S transmission will bolt up to the 996 engine, or do you need to fabricate an adapter?
Thank You.
Thank You.
yep it will bolt straight on sm all problem though you will have only 1 forward gear , but the upside is u will have 6 reverse gears and can attempt to beat the new reversing speed record set in England recently 163 kph u could use it though by changing the crown wheel and pinion hope this helps. greg
actually delete every thing i wrote yes it will work perfect i have just done this and its fine but u will need new drive shafts ,gear box brackets shifter cables and shifter cable brackets 4 some reason i thought u wanted to fit s box 2 996 car probably it was the lateness of the hr here in australia at the time many appologise if i caused any inconv greg
