Boxster door windows ajustement
Did somebody know how too adjust the window door on a boxster
you have two bolts ajustement under the door, What they do exactly ???
the cable that raises and lowers the window rides on a track. these two bolts hold the track to the door. the bolt positions can be adjusted so that the window leans in more (or less) - so that the top of the window will fit in the conv top window track when the window is raised.
