Boxster & Boxster S (986) Forum 1996-2004
Boxster tranny bolt patterns
Old 04-04-2003, 01:28 AM
Compression
3rd Gear
Compression's Avatar
Post Boxster tranny bolt patterns
Does anyone have any information regarding the bolt patterns on Boxster transmissions, both 5 and six speed?
Would a Boxster 5 or 6 speed tranny bolt up to a 993 3.6 or any 996 motor?
I have a friend who can pick up a new engine for his blown up Boxster engine. He found a pristine 993 3.6 for $5k. Will it work?
Any help is appreciated and thanks in advance.
Old 04-08-2003, 10:01 PM
box3.4L
box3.4L's Avatar
Post
it would be much easier to use the996 engine as there will be considerable hurdles to overcome with the 993 engine including the cooling of etc i have done the 996 conversion myself and it is not to hard . the performance gain is really quite staggering but yes the gearbox bolt patterns are the same
Old 04-10-2003, 07:51 PM
Michael Ghia
Michael Ghia's Avatar
Cool
The 996 motor will bolt up to a Boxster gearbox and work well. Definatley worth the upgrade.
The 996 gearbox is in a different housing and will not work the other way around in the car.
MG
Old 04-12-2003, 11:34 AM
bxtrgt
bxtrgt's Avatar
Post
Sorry to bring bad news, but 993 motor will not fit a Boxster tranny, 5 or 6 spd without some adapter being made. Then you have the problem of starter location. On a 996 and Boxster, it sits above the engine block. A 993 has the starter mounted to the trans, above the differential. The best thing to do is buy a good used 996 motor (Readily available for $5,000 to $7,500) and swap the external parts. E-mail me and I will be glad to help with advice. Its basically a remove & reinstall procedure.
Len Cummings
BoxsterGT
Lifetime Rennlist member
Quick Reply: Boxster tranny bolt patterns
