Boxster & Boxster S (986) Forum 1996-2004
Passenger side mirro
Old 01-11-2007, 03:50 PM
clb0099
clb0099's Avatar
Default Passenger side mirro
I brought my car to get all the wires replaced on driver's side and passenger doors due to the wires corroding which made the windows not work . After the passenger side was fixed the mechanic told me he noticed the mirror did not work but the driver's side did. My question is it possible for the swtich to go bad on one side. The mechanic suggest that was the problem but I want to know if anyone else had this issue. The wires and seals were updated to porsche standards . I checked the fuse and it is not blown .
Old 01-11-2007, 03:53 PM
clb0099
clb0099's Avatar
p.s firehawk try not to rip my head off since i went to a mechanic and this is what he told me ....
Old 01-11-2007, 05:00 PM
99firehawk
99firehawk's Avatar
i wont rip your head off unless you make 15 posts about the same thing,
did they work before he did the work ?
Old 01-11-2007, 05:27 PM
cdodkin
cdodkin's Avatar
You sure that the mirror hasn't just popped out of the track behind the glass in the mirror housing?
So the motor and mech are moving, but the plastic link to the mirror is not connected.
Had it happen on my Boxster, when someone hit the mirror.
Didn't look any different, but it didn't move, and when I tried moving the mirror by hand, it moved really easily because it was no longer connected to the tracking mech.
You could also hear the mirror motor if you had someone try the mirror adjust controls while you listened next to the faulty mirror.
Solution was to pull out the mirror glass, make sure all the mech was ok, then re-attach so it was locked in again.
Took 10 mins - but took some nerve, because you have to pull like hell to get the mirror off!
Old 01-11-2007, 07:54 PM
clb0099
clb0099's Avatar
not do sound stupid but i rarely move the side mirrors so i never noticed if they worked or not. I mean the driver's side worked when i got it back from the repair cause i had to adjust it but the other one never used it or checked to see it worked . I will try and listen if it's making any noise but I don't recall there being any noise when I last tried tio move it. I bought a digital multimeter to test the wires but any other suggestions if the mirror isn't off the track?
Old 01-11-2007, 08:12 PM
99firehawk
99firehawk's Avatar
pull the triangle off on the pass side door and see if the mirror is pluged in
Old 01-11-2007, 08:15 PM
clb0099
clb0099's Avatar
ok car is at home i am at hq .. but i will check that.. my dumb *** bought a switch the mechanic told me that is was it.The wires that run through the door to the window motor have anything to do with the mirror. Cause they replaced 43 wires and connectors. Porsche said that it needed to be updated the wiring harness for the window motor wires and seals because water gets in and corrodes them.the reason i ask about the 43 wires is there is 2 sets of wires . The one with 43 and another with several wires. I have the reciept of all the part numbers of what i got to replace both doors.
Old 01-11-2007, 10:16 PM
99firehawk
99firehawk's Avatar
the same harness as windows goes to to the mirrors through the door jam. theres a 2nd harness from the door harn4ess to the mirror harness then to the miror motor
Old 01-13-2007, 06:33 PM
clb0099
clb0099's Avatar
firehawk will not be able to look into this until tues.. the car is in the bodyshop installing a bodykit .. I will let you know
Old 01-13-2007, 10:31 PM
99firehawk
99firehawk's Avatar
mmmmmmmmk
Old 01-16-2007, 01:46 PM
clb0099
clb0099's Avatar
let me ask a question so in total there 43 wires between the 1st and 2nd harness?
Old 01-16-2007, 01:59 PM
99firehawk
99firehawk's Avatar
I dont know ive never counted them
Old 01-21-2007, 01:12 AM
clb0099
clb0099's Avatar
ok .. i checked the plug and it is plugged in.. let me ask you i bought a multimeter can u give me alittle advice on how to use it to maybe see if there is a short. Also there is no noise coming to the mirror at all.
Old 01-21-2007, 11:50 AM
99firehawk
99firehawk's Avatar
ill need to see a wiring diagram ill let you know tomorrow
Old 01-21-2007, 02:12 PM
clb0099
clb0099's Avatar
cool
Quick Reply: Passenger side mirro
