Common part #'s for DIY'ers
Rather than searching for individual part #’s we all need, I thought this might be helpful to everyone to have them in one spot.
Here’s some to start off and if anyone has any others we may need, add them to the thread.
These are for a 2000 “S” and should be the same for all, but double check as plugs for instance I believe are different.
For hard tops and speedster humps:
Spin Lock Left #986-563-713-03
Spin Lock Right #986-563-714-03
Bolts (2 needed) #999-219-041-00
Plastic Caps (if you don’t have them, 2 needed) #986-561-655-00
Maintenance Items:
Fuel Filter #996-110-253-01
Air Filter #996-110-131-04
Particle Filter #997-571-219-00
Oil Filter w/ O ring #996-107-225-53
Drain Plug Washer #900-123-106-30
9204 Filter Wrench #000-721-920-40
Beru Plugs #999-170-207-91
Miscellaneous Items:
’03 Red/Clear Taillights (sold as a set) #000-044-900-68
’03 Clear Side Markers (sold as a set) #996-631-043-01
Updated Radiator Cap #996-106-447-01
Maintenance Items:
000, 40, 721, 90012310630, 920, 98656165500, 986563713, 98656371303, 996106447, 99757121900, 99921904100, hump, kit, part, porsche, speedster
