Boxster & Boxster S (986) Forum 1996-2004
track tire sizes help
Old 06-24-2006, 12:34 AM
dgreenb1
dgreenb1's Avatar
Default track tire sizes help
I have a 1999 986 with a spare set of stock wheels- 17x7, 17x8.5. What would be the appropriate tire sizes for Kuhmo or Toyo R compound tires?
TIA
David Greenberg
Fort Myers. Florida
Old 06-24-2006, 08:37 AM
mjw930
mjw930's Avatar
Stock sizes are:
205/50x17 - Front
255/40x17 - Rear
Optional front: 225/45x17 which should work fine with your 7" wide front rim.
From what I see you need to bump up to the 225's to get a decent selection.
Old 07-05-2006, 02:00 AM
Gramps47
Gramps47's Avatar
Default Tire sizes
The best autocross tire set up is 245's all around on the Boxster. But, for me, 225 fronts and 255 rears would be the way to go. Also, get a good performance alignment.... 0 toe and .7 neg camber. This will compensate for the factory builtin understeer....Best of luck
Quick Reply: track tire sizes help
