Strut Braces
You know I really want to myself. I know there is some flex because when I go in and out of a driveway at an angle the to creaks a bit. I was told though by several sources it was a waste due to the regity built into the car. I cant say I am good or fast enough to be able to say that my last trip in the mountains would have been faster or more responsive had I had them. I think the carbonfiber front one would look cool but then you have to remove all the covers to see it anyway. I elected not to. I have an S , so not sure if that makes a dif.
Super Moderator
Yeah, I get the driveway creak as well, as tight as the chassis seems to be it's still a roadster and I have to believe the extra support would help.
This is a hotly debated topic. There are a few that swear that they completely transform the car. However, the majority say they're a complete waste. The factory has built-in strut tower braces that are far beefier than any aftermarket that I've seen. The GT3/cup cars also do not use aftermarket strut bars. I have researched/asked around on this topic extensively. There are several very inexpensive aftermarket strut bars, and I have not even bothered with those.
It is my opinion that the structural limitations in the Boxter are in the middle and not the ends. Considering the factory structures and factory braces, I think trying to further stiffen the ends is also a waste. Even the flex in the middle is only apparent when you really start to push the limits of suspension tuning. A roll cage would likely have a much more profound and noticeable benefit.
FWIW, I recall reading that the 986 (cab) is torsionally as stiff as the 993 (coupe).
Super Moderator
Marc,
Open the front hood and remove the plastic covers around the battery. If you look at the strut towers you will see thick diagonal braces. I personally find it hard to believe that a tiny additional strut brace would have any effect whatsoever.
But, hey, I've been wrong before!
Gary
Gary
