will these wheels fit a boxter/s
hi guys, hpoe ya dnt mind me posting over here but ive got some wheels for sale and was just wondering if anyone could tell me if a set of wheels with these dimension will fit a boxster. 10Jx18H2,T30,ET47 Rears and 8.5Jx18H2,13t,ET52 fronts,thanks in advance for any help chayten
Assuming you're talking about an '00-04 Boxster (986), they should fit fine. I have 10x18 ET48 & 8.5x18 ET52. You will have 1mm more outboard than I do in the rear. Oversize tires may present a minor rubbing problem at the rear fender lip.
Yes, should fit like a glove assuming they're not abnormally thick metal or anything strange. The back of a Boxster is very tight, but 47 or 48mm is the correct offset to get a 10" to fit.
