looking for the S
looking for the S
hey everyone, first post here, looks like a great forum. ive always been a japanese tuner guy but have recently started to have an affection for porsche....
i think the boxster/ boxster S is a great way to get into enjoying a porsche, of although i know there are cheaper options
i'm in ohio thinking of looking for an S or maybe a regular boxster, what model years would you guys recommend for with a budget of around $25k. thanks
Originally Posted by Paul Marangoni
Get the newest model you can afford. Porsches generally get better with each year's revision.
good to know, but is it a better idea to get a newer model regular boxster than an older boxster S...?
Well, it would depend on how new the regular boxster is and how old the S is. Personally, I would go for an S. You can probably find some really great deals out there on used ones.
I'd look for an S as well, although there's nothing wrong with a standard Boxster. The only exception is if you can foot for a 2003 or newer standard Boxster (in the $30k range) because they have a glass rear window vs. the plastic unit on all Boxsters pre-'03. (A post '03 Boxster S will be out of your price range.)
And (of course), FYI I think my brother is still selling his... http://www.lumpocole.com/
By the way, where in Ohio are you?
If you're a tuner guy, start with an S. No point in spending $K's on a 2.7L to get you to 3.2L levels at best. The S came out in 2000. I'm pretty sure it was 2003 that there was a minor body "refresh" and a bump in the S HP from 250 to 258 with the addition of a rear glass window. A 2003 for $25K might be tough to find unless it was high mileage. You should be able to find a 2000-2002 for $25K. The range is probably $25K to $35K. Most Porsches are tell taken care of.
thx for the advice guys, good points all around. it looks like an 03+ S is a nice target to shoot for if i can find a decent one between 25-30k.
i'm from cleveland btw....def not porsche weather this time of year
Hi,
I have a 2000S and when I bought it I hesitated with a 2003 model which at the time was about $10k extra right into 996 prices. I just wanted the glass window, the redesign of the rear bumper + glove box did not really appeal to me. Of course the extra 8 ponnies are good but still not worth it, same thing for clear lights. In my opinion save the price difference by getting a 2000S, buy a set of clear lights $150 which I did. Once your rear plastic window gives up install a new glass aftermarket top costs about $ 700. Install an Evoms intake for $ 400 to get those 8 ponnies back and you are good to go.
I know the price difference between a 2000S and a 2003S is no longer $10k, but since it is out of your budget anyway. Why not get the 2000S and spend at your convenience about $ 1,200 to add the similar features of a 2003 model.
Here in California you cannot get a nice 2000S for $ 25k it is closer to $ 30k.
Good Luck
Good Luck
Originally Posted by Renaud Bizet
Hi,
Good Luck
Good Luck
you also bring up some great points there, especially considering id be into making my own modifications over time
That is right, first you limit the scope of the depreciation by avoiding an extra $10k in depreciation.
Second you won't spend that money at once. I mean your top can last let say 2 years before you spring for the upgrade.
I don't know it is up to you. That was my reasoning at the time and I am glad I did not burn the extra cash as my car will not be worth much in the long run. And I would rather use it to add a Cayman in some years in my garage.
interesting you bring the cayman into the convo, i was thinking the same thing with a 911 eventually. im still neutral on the cayman, but im also new to the porsche community, i have heard some good and bad things on it so far.....
the 00/01 S with fairly low mileage seems to be in the 25-30k range in my area right now, seems like a good place to start narrowing
