Boxster & Boxster S (986) Forum 1996-2004
Path to rear trunk?
Old 02-12-2005, 02:59 PM
mjones2
2nd Gear
mjones2's Avatar
Default Path to rear trunk?
Can anyone direct me to a pre-existing path from the passenger compartment to the rear trunk? Specifically a path suitable for 1/4" diameter coax.
Some may consider this blasphemous, but I need 2-way radio capability in my boxster. The transciever will be mounted in the front trunk where the cd-changer would mount. The control head will be mounted on a bracket that will be form fit to the lower cubby above the batwing.
Any suggestions are greatly appreciated...
Mike
Old 02-12-2005, 11:22 PM
Turboflyer
Turboflyer's Avatar
Could it possibly slip through with the ECU feed from the trunk?
Old 02-13-2005, 12:52 AM
Moogle
Moogle's Avatar
follow the path from the CD changer to the head unit
Old 02-13-2005, 02:19 PM
mjones2
2nd Gear
mjones2's Avatar
Thanks for the response.
I've only had the car for a couple of weeks, and I haven't started pulling panels off yet. I'll investigate your tip!
Mike
Quick Reply: Path to rear trunk?
