rear tire wear
rear tire wear
So, for all the mechanics out there and all the hands on owners. We know that to get the rear of a boxter to align you are pretty much at the end of both the camber and toe adjustments. Has anyone tried putting cup parts on the rear of a boxter to get more adjustment out of it?
Jim, my car just went into the shop this AM for a new suspension. I was told that the stock rear camber adjustment will give me all the camber I would need. Is that not the case?
well, if it's bent yes. However, the cup stuff has a second adjuster that would allow you to remove the arm and give it more or less base adjustment before you started using the eccentric adjuster. I just wondered if anyone had tried it yet. It should not be to tough to fab if not.
