Help ! 97 Boxster dumping coolant
6th Gear
Hi, I replaced a cracked coolant reservoir in the trunk last week and have been unable to get the car to stop dumping coolant when parked hot. I suspect a bleeding problem. The 97 had the bleed line on the block and the '98 and on moved the line to the top of the oil cooler. Are the '97's hard to bleed?
I have tried filling with the tail high and reving the engine etc. Seems to run a little hotter than before also...needle in the middle of the zero of 180. Doesn't boil over all the time but often enough.
Any help greatly appreciated!
