Boxster & Boxster S (986) Forum 1996-2004
Fuel injector for Frankenengine
Old Nov 7, 2025 | 09:55 AM
Dllrd23's Avatar
Dllrd23
Default Fuel injector for Frankenengine
I’ve rear through most of the posts on this subject and thought I would get the group’s opinion. I have a 2.7L 5 chain engine out of a 01 Boxster going in a 1999 replacing a 2.5L. I have kept the original intake crossover and used it as the front. So that I could retain the cable driven throttle body. For the fuel rail I used a 3.4L rail because it bolts up directly and is a return type. What fuel injector do you recommend? Still running the stick computer with no tune (yet). I don’t think I can run the 2.7l as they go on a returnless system. That leaves me with the 2.5 (no specs found) or the 3.4 injectors? What is your opinion?
Old Nov 12, 2025 | 01:54 PM
76FJ55's Avatar
76FJ55
Are you certain it is from an '01? or maybe I'm mistaken, but I believe our 01S 3.2 is a return system and shares the same fuel rails, pressure regulator and injectors as the corresponding non-S 2.7 for '01. I think the change to a non-return system occurred in '02, but coincidentally '01 on used the same fuel injectors, so presumably you can use the injectors from the doner engine.
Edit:
You mention 3.4L several times in your post. Are you using 911 (996) parts as well? what year? also the same injectors for the '01 2.7/3.2 (986) are spec'ed for the 3.4/3.6 996.2001-2005.
Old Nov 13, 2025 | 05:48 PM
Dllrd23's Avatar
Dllrd23
Oh boy is my memory starting to go! Engine is a 2.7 from an 02. Fuel rail was originally a return less system. When I went to put the 2.5l fuel rail on, the mounting points did not match up. Someone on another forum swapped me a fuel rail that was a return type that bolted up directly to the 2.7 manifold in exchange for my 2.7 rail and injectors. I thought he said it was out of a 3.4 but now I have to go back and check. I’ll update tonight.
