03 Frunk refuses to open via popper button.
Feeling stumped right now with my frunk issues. Car is an 03 with the electronic release. Button inside the car doesn’t work, i’ve tried replacing the switch inside the cabin, and have also replaced the latch/actuator assembly, still doesn’t work. Checked my grounds + wiring + connectors, and all look clean. What else could I be missing? The most frustrating part is the emergency pull inside the frunk works perfectly. For now i’m using the emergency pull wire hidden behind the tow hook, but it’s far from ideal (especially because as I was going to replace the latch/actuator assembly last night my emergency cable broke causing two additional hours of hell, luckily the new latch came with a new emergency cable). Another thing that may tie into this is I believe my car has some kind of immobilizer issue, as my window switches and door locks don't work, could this be related? From what I understand the two systems are separate, but you never know.
Has anyone done a manual frunk/trunk latch retrofit? I know the earlier cars have manual pulls for their trunk/frunk, and i'd much rather have that vs worry about this. Another idea I’ve had other than a manual retrofit is extending the wiring for the internal emergency release to the interior since it works perfectly fine, seems fairly simple to do once I find somewhere to pass the wires through + somewhere to mount the pull.
Received 1,855 Likes
Check the FUSE. Then check and see if you're getting voltage to the actuator from the switch using a multimeter. I recommend getting a schematic that can be found in the service manual. That will help you trace the path from the switch to the actuator and then to the lock mechanism.
Porsche 996 997 Carrera 911 986 Emergency Hood Trunk Lock Cable Release Actuator | eBay
Did some troubleshooting last night - so everything up to the plug that connects to the latch is okay. Fingers crossed that new actuator will solve my problem!
If you dig you’ll find a thread from one of the 996 guys that figured out it is a thermo resistor in the release mechanism. You might notice your problem is temperature related.
New release is supposed to fix it but I’m with you, rather have a cable
stomish (05-22-2024)
Interesting.. I wonder which part, if it's in the latch or the actuator itself. Will do some searching for that thread! I'm just grateful at least my emergency popper still works for the time being
I couldn't get the frunk on the 997 to open. lifting the lever didn't work. I learned to lift the lever with gentle pressure by the lever's hinge on the inside it works. Screwy, but works. use my left index finger to lift while my thumb applies the pressure. Like a freaking medical procedure to open the dang frunk.
