Boxster & Boxster S (986) Forum 1996-2004
Trunk and alarm ???
Old 01-12-2023, 11:12 PM
Tolley38
Tolley38's Avatar
Default Trunk and alarm ???
New owner questions….
When the trunk catch is released should the trunk lid fully open by itself? (ala mini van)
I didn’t know my new to me 99 base had an alarm until it went off in my driveway just now.
I will assume this was a fluke since it hasn’t done it in the two weeks I’ve owned it.
I’ve studied up on activating and shutting it off (don’t want to be “that guy” at 2 in the morning)
but I’m wondering what will cause it do what it’s supposed to do. A bump? Door handle? Jacking it up? Is it trustworthy? I’ve read that some people have disconnected the alarm horn and that makes me wonder if it’s even worth chancing a false alarm in the middle of the night.
Old 01-13-2023, 08:56 AM
tcora
tcora's Avatar
no
do you have, and, if so, have you read your owners manual?
Old 01-13-2023, 02:23 PM
BondJ
BondJ's Avatar
Check the battery. How old is it? A crapped battery will trigger the alarm. If poss use a Ctek or similar maintainer if the car is not driven regularly
Old 01-14-2023, 07:55 AM
Tolley38
Tolley38's Avatar
thanks. The battery is young and strong but I’ll have it checked anyhow.
Old 02-07-2023, 07:57 PM
elav
elav's Avatar
This could be caused by a flaky ignition switch. When you lock the car does it not make a noise, honk once, or honk twice?
Old 02-07-2023, 08:07 PM
Tolley38
Tolley38's Avatar
Thank you for the response.
I cured the problem by trading the car in on a pristine 2014 Boxster base. 😁😁😎
Quick Reply: Trunk and alarm ???
