Boxster & Boxster S (986) Forum 1996-2004
Pics of My Modded 986 Boxster S
Old 01-15-2023, 09:13 AM
tcora
tcora's Avatar
Originally Posted by JJJMCD
Thanks! They were around $1,000, which is actually pretty reasonable considering what a set of used Porsche litronic headlights cost. Here is the listing on eBay for them:
https://www.ebay.com/itm/30427473344...ya4000b2n00004
[no affiliation with the seller]
Question for you on beam pattern, etc. Did you take and “before n after” pix showing that? My 986 is a daily driver, and the factory lighting is rather beat, so that’s kinda important.
Thanks.
Old 01-15-2023, 03:42 PM
JJJMCD
JJJMCD's Avatar
Thanks.
No, I didn’t take any photos of the beam pattern.
As I noted earlier, visibility with them is MUCH better than with the factory headlights.
Like a lot of xenon lights, they’re set up so that top part of the beam on the left headlight is a little lower than on the right headlight, so you don’t blind oncoming drivers.
Although you can install them yourself, I had mine professionally installed so that the beams are properly aimed.
Quick Reply: Pics of My Modded 986 Boxster S
