Radiator leak?
Radiator leak?
Recently drove and had my some kind of coolant issue as a liquid sprayed out from the passenger side headlight area and then a coolant light came on the dashboard. After parking my car I noticed a leak coming out from the passenger side front wheel area and some hot liquid (I assume coolant) also coming out from the passenger headlight area. It does not appear to be leaking anymore after I have filled it with coolant as it was just above minimum coolant level. Anyone have any insights as I am scared to drive my car and would like to fix it myself if possible. Thank you
I would also advise that you look to pick up a copy of the Bentley manual for reference.
