Dropped nut in battery compartment
Newbie here. Today I was attaching the leads for my winter battery charger and i've stupidly undone the bolt for the positive terminal and dropped it somewhere in the compartment below. I have a spare bolt so i'm not concerned with the part being missing but I am concerned with it rolling around causing damage in the compartment or getting into the drains. Where has it likely dropped? I can't see it anywhere!
uk986 (09-03-2021)
IIRC, there is a drain under the battery tray - you really don’t want it to clog. It’s a fairly trivial matter to pull the battery and the tray, and while you’re in there, you can make sure there is no debris in the drain.
The following 2 users liked this post by tcora:
Dr. C (05-11-2023),
westcoastj (05-11-2023)
The likelihood of that bolt finding its way into a drain AND blocking the drain is extremely low. I understand the concern over the FOD (Foreign Object Damage) and it's a good one but where you dropped it is simply not a concern in my opinion. Look for it but don't worry if you can't find it.
911AdmirerEst76 (05-27-2023)
tcora (05-16-2023)
There's a drain under the battery. I'd give odds that the nut is sitting on top of the drain - not a good thing. You may have to yank the battery to get at it, or maybe the magnet on a wand trick will work for you. Better to find it now, than to find it's clogged the drain later!
