tips on first ever track day with a Boxster?
I've never been on any kind of a road race track with anything, I may have a chance in a couple months to attend a club track day at Limerock in CT with my '99 Boxster. How do I keep myself from looking like a fool? Or maybe less like a fool?
My car is in top shape brakes, suspension, engine, clutch, transmission, etc. I'm just wondering what's the most annoying thing rookies do at tracks that maybe I could avoid. Anything I should do special with the car? Obviously I know enough to make sure everything is out of the car, windows clean, and to make sure all fluids are up and to idle it for a while after running hard before shutting it down to let the turbo cool down. Any advice is appreciated.
what turbo?
the reality....listen to your instructor. Thats the most important thing to worry about. After that, keep your eyes up, focus on the line instead of speed, and make sure you keep an eye on your mirrors so you don't cause any long line of cars.
most importantly, have fun
My car has a turbo 4cyl. I don't think there will be an instructor, I could be wrong on that though. So, can I assume just keep to the right and allow people to pass on the left? Are you always supposed to pass on the left?
no, the rule is that you stay on line and the passing cars will be offline. That can get tricky on transitions from left to right, but since this isn't racing, the key is to be predictable. Always pass with a pointby only.
As a newbie without an instructor, I'd probably try to watch some track videos ahead of time so you can get a sense of the line through certain unique turns at LRP like big bend and the transition after the left hander.
Track specific, you will want to make sure when you go up the large uphill, at the crest your steering wheel needs to be dead straight. Try to brake less than you think for the downhill right hander as the compression will give you good grip.
Keep an eye on tire pressures and fluid temps. I remember now your thread on the 1.8t motor swap, not sure how they are on track so can't speak on that.
I wouldn’t do this. Just inflating a few pounds over stock can result in a very squirrelly handling car.
I inflated my tires to factory street spec, and after the event, I had to LOWER my air pressure quite a bit, maybe 4-5 psi. I actually had to keep lowering my pressure after every event.
But, yes, bring a pump and gauge, just in case.
I am a PCA instructor but have no experience with LImerock. For all of our events and every PCA/NASA zone that I have run with we do not allow inexperienced students to run without instructors. When I go to a track that I have not been on before I will ask for an instructor for at least the at least a couple of laps. Do with that info what you will. Many, but not all, HPDE events will require a tech inspection of your car to be allowed on track. Get a copy of the form they use ahead of time and go through it yourself to avoid any surprises.
The most common issues I see with new students is they have not recently changed brake fluid. These events start early in the morning - on track at 8:30 means a driver meeting could be 7:30 which means you need to be there at 7 because there is a line at the gate to get in, which means you need to leave the house by 6, which means ... Add to that you are amped with excitement the night before and getting good night sleep takes planning.
check your pride at the door. and be situationally aware. it's easy to get overwhelmed if this is your first track experience
My pump has a gauge on it, so that’s why I use it, although I do envy the folks that have those Longacre brand gauges. Those a nice.
The PSI on the tire is a "cold" spec 68 degrees ambient assumed.
If you push the car you need to adjust tire pressure.
If your first DE is a parade lap day focus then previous comments arrive and drive and smile.
All students I have had the pleasure of riding with want to push their P car around the track and feel the speed, G's and braking limits of their car.
Doesnt mean they will be fast right out of the gate but its not a parade lap day either.
1. Tech your car and address anything needed
2. Be prepared to adjust tire pressures as day progress - heat of the day and trust me you will get faster and high pressure will mess you up
3. Learn the track and flags before your arrive - you should be able to close your eyes and drive the track hitting apex in your head
4. Listen to your instructor - If you dont like your instructor after first session ask for a different one. Not personal just can happen. Dont be shy about it youre there to learn
5. Have fun!
5. Have fun!
Thanks for all the tips! Lots of useful information here. I see in videos a lot of people tape up their lights, is that really needed? I would imagine tracks are kept pretty clean of debris or is there another reason for it?
