Boxster & Boxster S (986) Forum 1996-2004
Rear end chattering at idle and takeoff
Old 03-26-2019 | 12:04 AM
BRC's Avatar
BRC
Default Rear end chattering at idle and takeoff
My 2000 S makes a kind of metallic chattering noise at idle (in neutral, clutch engaged - the sound stops when I press the clutch in) and when taking off (letting the clutch out). It's not very loud; I can really only hear it if there's a wall next to me for the sound to bounce off of. It also only occurs after the car is warmed up; completely silent when it's cold. Once the car is moving, it's flawless and sounds perfectly fine at any speed in any gear.
A few months ago I did pretty much everything back there - clutch, flywheel, IMS, slave cylinder, gearbox oil - all brand new. The noise existed both before and after I finished and doesn't seem to have gotten any better or worse.
I'm not all that worried about it, but I'm curious nonetheless. Any idea what it could be?
Old 03-26-2019 | 08:48 AM
986ster's Avatar
986ster
Did you replace the throw out bearing when you did the clutch?
Old 03-26-2019 | 12:43 PM
BRC's Avatar
BRC
Yep, new throwout as well
Old 03-26-2019 | 12:49 PM
Macster's Avatar
Macster
My Boxster -- with a 5-speed -- manifested a very faint noise similar to what you describe the noise being clutch disc and transmission chatter/rattle.
I have no experience with an S.
But my 996 Turbo manifested the noise, too. And it was more noticeable. It only really was present after the drive train was fully warmed up. I'd roll up to a stop slipping the shift lever into neutral and releasing the clutch pedal. Then I'd here the irregular rattle. I could make it go away be pressing the clutch pedal down all the way then released it again.
I could make it reappear by revving the engine then the noise would be back after the engine returned to idle.
At some point after new O2 sensors or new coils/plugs -- the sensors were done at 132K miles the plugs/coils done around 140K miles -- the noise was gone. Seems something I did (had done) smoothed out the engine idle and the transmission rattle went away.
Old 03-26-2019 | 09:01 PM
ltusler's Avatar
ltusler
Its normal, don't worry about it, just the shift forks or gears when warm. Its really noticeable without a dual mass FW.
Old 03-27-2019 | 01:08 AM
patdonahue's Avatar
patdonahue
2001 Boxster S 24000miles, original clutch, throwout bearing, etc. except for IMS replacement at 14000. Does exactly the same thing, glad I saw this post!
Old 04-03-2019 | 11:52 PM
BRC's Avatar
BRC
Managed to pick up the sound on mic really well tonight:
https://streamable.com/3e9un
Sound about like what everyone's talking about here?
Old 04-27-2019 | 04:48 AM
BRC's Avatar
BRC
Anyone taken a listen to that video yet?
Old 04-27-2019 | 11:59 AM
paulofto's Avatar
paulofto
I listened to it but the recording is short and quite honestly it didn't sound unlike mine which I think is normal. Some mechanical noise is expected especially when the clutch is engaged and there is no tension on the gears in neutral.
Old 04-28-2019 | 04:05 AM
BRC's Avatar
BRC
Thanks for the input, it's more reassuring when someone actually hears the sound. Maybe I'll try to get a better recording at some point
Old 05-07-2019 | 11:42 AM
Macster's Avatar
Macster
Just listened to the clip. I agree with what you said. Really it sounds like normal clutch disc transmission rattle that occurs in heavier manual transmissions when they are warmed up.
To the OP: If you want a 2nd opinion have a Porsche tech give a listen and offer his opinion. They hear all sorts of noises all the time and can distinguish between normal and abnormal rather quickly.
Old 05-07-2019 | 04:57 PM
Starter986's Avatar
Starter986
Had the clutch and TOB replaced in my 86 BMW 325es a couple thousand miles ago (5 years ago). I had that noise BEFORE the clutch/TOB replacement... and it remains.
Must be the new normal.. and the "heavier" sounds correct.
Quick Reply: Rear end chattering at idle and takeoff
