Dome/Micro Switch
Dome/Micro Switch
99 Boxster Base. Both windows don't roll all the way up unless I shim a small piece of rubber between the 'hook' and the latch. Am I correct to replace the micro switch located in the dome light? It only works with a shim .....if I push it with my finger it doesn't work either. Thanks V
A search for Boxster top latch switch ought to get you a good selection of hits and probably a good DIY write up maybe even a video of how to deal with the switch.
