P0304 not a coil or plug issue.
8th Gear
Hello all!
I am getting a P0304 misfire cylinder 4 on my 2003 Boxster base. This ONLY happens when I floor it from standstill or floor it from lower speeds. If I floor it while already at higher speeds it does not occur. The coils and plugs are less then 1 year old and I swapped the coil and plugs between cylinder 4 and cylinder 1 and the problem did not move.
What any you oh wise ones? Injector? Cat going bad? Thanks in advance for any help.
- Scott
- Scott
8th Gear
Update
Added some Techron to the gas tank. Drove around awhile to get engine nice and hot. Still getting code flashing but now it doesnt stay on for me to check if it is still P0304. From flooring it the light flashes between 90-100 mph then goes out. Interesting... perhaps a few more Techon treatments and it will go away?
Swap injectors if the Techron doesnt clear it up.
Also check spark plug gap and double check coil click stap in plug is seated.
8th Gear
8th Gear
Update
Forgot to also mention it is a Tiptronic. Anyway update after today's drive of 50 miles:
Flooring it from standstill or lower speeds still turns on the flashing engine light. It's consistently between 90-100 when it flashes. If I keep it floored and go over 100 it goes away. If I slow down below 90 it goes away. If I keep it in the 90-100 range with it flashing it will go solid and with the P0304 misfire cylinder 4 code.
Next fill up I will do another bottle of Techron. After that it's on to checking or swapping the injector.
If I were you, I would swap the injector to another cylinder just to eliminate that, then pull the head cover on bank 2 and have a look at the cam and lifters..
8th Gear
Sorry for long wait for an update - I tried a couple of bottles of Techron over the last 2 months but no dice. Then Scott K at Fabspeed suggested trying Lucas. One treatment with Lucas and voila no more code when flooring the car. I will drive it hard this weekend and see if any change but so far so good.
- I did buy and have a spare injector to try next if the issue returns.
Sweet.
Good news.
Good news.
