Disaster? Turned crank while cam was locked
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Help! This weekend I installed an IMS retrofit bearing, but after putting the chain tensionsers back in, I forgot to remove the cam locking tool before turning the crank with a wrench to remove any slack in the timing chain. The cam lock popped out, but I don't know if any damage was done. When the engine is locked at TDC, the line on the cam does still appear to be straight up and down. What should I do?
Post a picture
I would check the timing of both banks. TDC on bank 1 and then rotate 1 revolution and check the timing on bank 2. With the tensioners in it would seem improbable that the chain(s) would have jumped. As Byprodriver states, photos would help.
If the pic's were taken at TDC I can't see any problem with the timing. I would rotate the engine CLOCKWISE a couple revolutions back to TDC, if the cam timing notches still look the same you are fine.
Former Vendor
Turn the engine 720 degrees clockwise and repost a photo of the timing. On a 5 chain engine this is much more forgiving than a 3 chain, as the staking tool does not fully engage on the 5 chain.
We’ve had this happen in a class many, many times and the timing is usually retained. We actually try to make this happen in a class to show the attendees how easy this is to forget.
