2004 Boxster S headlight washer nozzle missing
Hi guys, my new Boxster is missing the right hand passenger side headlight washing spray nozzle on the bumper, is it even worth fixin and how.
Do some searching here and at '986Forum.com'. There are a few write ups about this issue. The little nozzle '*****' pop out when the socket they sit in gets cracked, a very common issue in colder climates with freeze/thaw cycles. Unfortunately the nozzles themselves are not available separately, you have to buy the entire nozzle assembly at close to $200 bucks each. There is a hack out there to buy a BMW based nozzle assembly at a fraction of the cost and cannibalize the '*****' but I tried it and the ***** shot out the first time I used the sprayer. I simply took out the fuse to the sprayer and live with it just like cars without headlight cleaners.
The day I test drove the 2004 S that I own I inadvertently hit the headlight wasters and both nozzles on one side went flying and were never found again. The seller did replace the washer, but as a result of that experience I never use the headlight washers,
Here's your solution:
These just pop right into place on the Boxster
$28.
I did it.
Been in place for two years now and haven't blown out yet.
https://www.ecstuning.com/b-genuine-...t/61674290868/
Enjoy!
$28.
I did it.
Enjoy!
$28.
I did it.
Enjoy!
$28.
I did it.
Enjoy!
